high temperature thermistors 1
pesy
Are there any low cost thermistors that can operate up to 350C or 400C? I am trying to measure the temperature in a flue that can get up to ~700F with a probe that connects to a circuitboard I am designing. I'm not sure if I need PTC or NTC, but I can probably make it work with either.
Pesy
Although you can get thermistors that operate at these sort of temperatures, a quick check on several websites suggests that the packaging of the device may not be ideal for placing inside a flue.
Have you considered using a linear resistance type (e.g. PRT) or even a thermocouple? These are usually available in ruggedised stainless steel sleeves which can be mounted with various bushes or glands into the flue, and are more able to withstand flue gases.
Use a thermocouple.
They have well-defined characteristics, while a thermistor has rather more variable characteristics and may need to be specifically calibrated for each individual thermistor. The t/c will survive for a long time in the flue duct if you spec an industrial type with a stainless or inconel sheath.
If we learn from our mistakes,
I'm getting a great education!
