May 16, 2011 #1 breaker34 Mechanical Joined Mar 31, 2010 Messages 24 Location US Does anyone have any experience with high temperature o'rings, or if there is such a thing? Looking at a ring that can withstand the API fire testing for a high pressure valve. Any suggestions?
May 17, 2011 #2 GrahamBennett Materials Joined Feb 1, 2007 Messages 1,308 Location GB Viton or silicone Upvote 0 Downvote
May 17, 2011 Thread starter #3 breaker34 Mechanical Joined Mar 31, 2010 Messages 24 Location US I am looking at 15k pressure rating. Also, I am pretty sure viton only reaches 400f. The fire test will see over 1100F. Upvote 0 Downvote
May 21, 2011 #4 johnchrc Mechanical Joined Jul 14, 2004 Messages 176 Location US Are they static? Look at metal o-rings (SS and high temp alloy steel tubing. They can handle the temperature to 1,800F). Try and search. There are several I know of. You can also design your own metal-to-metal seal. Try Garlock HelicoFlex. http://dymseal.com/html/Metal%20O-Ring.pdf Upvote 0 Downvote
May 24, 2011 #5 utkk Mechanical Joined Jan 30, 2011 Messages 15 Location TH You can use silicone, SBR, EPDM etc. Rubber engineering Upvote 0 Downvote
May 25, 2011 #6 Metten Materials Joined Feb 11, 2008 Messages 65 Location BE utkk: they will not survive such high temperatures. Upvote 0 Downvote
