In a high temp exhuast fan (i.e. 15-1600ºF), do you mount the floating bearing on the fan side or the sheave(drive) side?
Does the shaft grow towards or away from the heat?
If I mount the floating on the sheave side, I am compromising belt life because of sheave alignment? Is this correct?
