Hello Everyone,
I have created a Split Hopkinson Pressure Bar simulation setup in Abaqus to capture the force acting on the bars. However, the results I obtained are all single digit Newton values which is unrealistic for steel bars and an aluminium specimen. The impact velocity is set to 10 m/s. The elastic properties are defined for the bars. As for the specimen the elastic, plastic and damage model are defined.
For the force, I select an element on the bar (incident) and plot the NFORC VS TIME. With that the values displayed are not logical. I tried finding the CPRESS option but I can't seem to find it. In terms of the boundary conditions, all degrees of freedom are constrained except for the degree of freedom associated to the loading axis.
Any ideas to solve this issue?
