I have a process driving many screw conveyors in a mining facility. The material being conveyed is a fine powder. Generally we try to empty the conveyors at the end of a production run, but sometimed residual material is left in the conveyors. When this happens we need high torque to get them started again. Most of these conveyors have 10HP 460V 3ph induction motors on them. History has shown that a 7.5HP motor is not enough to start the screws, but when they are running 3HP is enough to keep them going. The PF of the 10HP motor is very low (.5) when running so lightly loaded. What methods have been used to solve this problem of the requirement for high starting torque but low running power? As you can tell we are oversizing the motor to avoid the problem but in the new super-energy-efficient world this option is becoming unacceptable. Could I use a part-winding motor in the opposite manner to that which it is usually applied? That is, disconnect some of the winding once the motor is started.
Tom Gilmartin, P.E.
Rutland, VT USA
Tom Gilmartin, P.E.
Rutland, VT USA
