alansimpson
- Jul 8, 2000
- 228
I am switching a 0.9 A current at 1V using reed switches and I am running into problems. Rotating wheel with 4 magnets on circumference
1)At high speeds (over 200 Hz) not switching.
2)Switch fails closed.
The switch is rated for an 1 amp.
Load is inductive so there could be surge current.
Would there be alternative available in semiconductor sensor for instance that could take speed. Must work with 1V supply and must consume minimal power.
Can't find hall switch to work at that voltage and current.
