To xr7755 For my purposes I wasn't that interested in what the actual cfm flow was. I was more interested in comparison of cylinder to cylinder variations. I used a 5 hp. rated vacume cleaner to draw a deppression for intake and 3 of them to blow into the system for the exhaust.
Typical 350 cu" V8 engine draws about 75 cu' per cylinder at 6,000 rpm. When the engine is on the dyno vacume readings are near zero at WOT throughout the rpm range (2,000-7,000) I was testing. The only demonstration of commercial equipment I have seen is at trade shows. The sales people are unanimous in that all testing be done at 28"hg. which they control by changing the orifice size of an iris like device. If I question why they don't just monitor vacume readings they look at me like I'm from some far away planet. I've even seen demonstrations where they draw a deppression on the combustion chamber side to check exhaust flow reasoning being "if it flows good backwards it will flow good in the opposite direction". They monitor cfm. by placing a turbine like device in the conduit between the pump and the bench. In the end I was able to achieve the results I was looking for using the method I described.----------Phil
