I have a question about high resistance ground device installation.
Does the device have to be connected to the main bus, or can it be connected to a branch circuit, which in turn, is connected to the main bus?
The application is for a 3Ph., 1500KVA ungrounded delta-delta feeding a 600V bus, that in turn has 3 branch circuits. One person says that it has to be bolted on to the main bus, another says all the branch circuits go back to the main bus anyway, so it does not matter.
Is there something fundemental about HRG systems that I am missing that stipulates where they are installed on the system?
