High Quality vs Draft Quality drawing problem
DigiBob
New member
Wondering if anyone else is experiencing problems switching from draft to high quality views in drawings? When I try to change my views to high quality SW kicks me out with the dreaded unhandled error.. When I try to switch to high quality during printing, I get kicked out with no error message. I really would like to print my final drawings so they don't look like raster images. Draft quality is good for checkprints.. I have not installed sp2.1 yet, but from the complaints I am hearing I am reluctant..
Bob
Bob Snead
Designer
Northropgrumman.com
SP2.1 took care of some problems I was having such as exporting proper DWG files. You might like it, depending on what type of work you're doing.
This sounds like it may be a graphics card issue. Have you made sure your graphics card checks out w/the list on the SW site?
If that's fine, maybe you need to turn down the settings for your "high quality" output in your "quality" area in Tools->Options for your System. The quality could be cranked a little too high and choking your graphics card anyway. All I can think of for now.
Jeff Mowry
Industrial Designhaus, LLC
Thanks,
turning down my image quality settings and installing sp2.1 seems to have done the trick.
Bob
Bob Snead
Designer
Northropgrumman.com
