I am asked to manufacture a tubular heating element with very special features, while I don't have experience enough in the heating elements field.
The requirement for the element is as below:
1- Type: tubular heating element with a coiled heating filament (buried inside insulation).
2- Length: 1600 mm (straight), OD: 9.5 mm, shealth material: Stainless steel
3- Power: 100 KW,
4- Resistance: 1.7-1.9 Ohm
5- Medium: flow of a liquid with temperature of 600 degree of Celsius, (surface of the element will be kept at 600 C).
100 KW power for an element with these dimensions is too high and I have a lot of worries about the element overheating and melting. How can I solve this problem?
The question is that, is such an element possible to manufacture?
if yes, can I use usual materials such as Nichrome for the heating filament and Mgo for the insulation??
what is the suitable materials for the heating filament and insulation of such element?
Thank you very much
Vahid
3- Power: 100 KW,
Thank you very much
Vahid
