krikstrebor
I recently had a code official require high efficiency furnace concentric vent terminations at the roof be terminated 10 feet from the property line. He used 2006IMC 501.2.1 #2 as his justification: "501.2.1 Location of exhaust outlets. The termination point of exhaust outlets and ducts discharging to the outdoors shall be located with the following minimum distances: 2. For other product-conveying outlets: 10 feet (3048 mm) from the property lines; 3 feet (914 mm) from exterior walls and roofs; 10 feet (3048 mm) from operable openings into buildings; 10 feet (3048 mm)above adjoining grade." To me this code interpretation seems to have several problems, 1.the item in question is a vent pipe and not an exhaust. 2. Product conveying exhaust is defined by some code amendments to be: Ducting used for conveying solid particulates, such as refuse, dust, fumes, and smoke; liquid particulate matter, such as spray residue, mists, and fogs; vapors, such as vapors from flammable or corrosive liquids; noxious and toxic gases; and air temperatures exceeding 250F. 3. Item 501.2.1 does not indicate which direction a termination must discharge to need the 10 foot clearance (horizontal/vertical). I did more code research and found under 2006IMC 804 direct venting integral vent and mechanical draft systems, the code requires 10' of clearance to a property line with vents using power exhausters. If I understand correctly power exhausters are mechanical fans installed at the top of the stack to provide draft and if I am correct this item does not apply. Next I went to 2006IMC 804.3.5 Vertical terminations and could not find a reference to distance from the property line but did find the following: Where the vent termination is located below an adjacent roof structure, the termination point shall be located at least 3 feet (914 mm) from such structure. Since the IBC does not provide a definition of "adjacent structure" I am not able to determine if that means a structure possibly on a different lot. So I am stuck without definitive language or evidence to support or deny the 10' away requirement. Has anyone had a similar problem and if so what was the determination and what evidence did you use to support it.
