Okui
Petroleum
- Nov 25, 2008
- 6
if there is high dp across the ball valve, will i have difficulties in opening the valve manually? some say yes..some say no....
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
zdas04 said:I've never seen any of the standards define the difference between floating ball valves and trunion ball valves. To me the difference is that a floating-ball valve relies on the ball shifting into the downstream seat to seal and a trunion has components to prevent lateral ball movement from either direction and has spring-loaded seats.
