Feb 12, 2016 #1 PatRymer Civil/Environmental Joined Feb 12, 2016 Messages 1 Location US I have been asked to use "high deflection couplings" on a water line plan I'm working on but I can't find any design info or manufacturer data. Any suggestions?
Feb 12, 2016 #2 ashtree Bioengineer Joined Nov 28, 2015 Messages 703 Location AU PatRymer Gibault type joints will typically give you 5-6 degrees. How much deflection do you need? Regards Ashtree "Any water can be made potable if you filter it through enough money" Upvote 0 Downvote
Apr 6, 2016 #3 Lan123 Civil/Environmental Joined Aug 27, 2010 Messages 155 Location CA Is this for new or a modification to an existing line? Upvote 0 Downvote
Apr 7, 2016 #4 bimr Civil/Environmental Joined Feb 25, 2003 Messages 9,380 Location US There are plenty of options. Joint deflection depends on the pipe size. See the attachment. http://files.engineering.com/getfile.aspx?folder=e9191f60-3af7-41b8-875a-54ea314dcee2&file=eadips_ebook_10_chapter_Mechanical_Joints.pdf Upvote 0 Downvote
Apr 9, 2016 #5 dicksewerrat Civil/Environmental Joined May 16, 2002 Messages 1,946 Location US Use bends, you will sleep better. Richard A. Cornelius, P.E. http://WWW.amlinereast.com Upvote 0 Downvote
