tigertommy
Industrial
I´m looking for a sampling valve for Heavy fuel oil, Air operated, 3 way as small as possible...orifice of approx 6mm.
The problem is that is should be able to run 3000 cycles per day all year minimum 3 years in service without repair.
The overall size of this valve should be small as we have limited space available...I´m not sure a ball valve would be able to withstand the high cycle rate...Any suggestions?
