High Current Low Voltage Plug Connectors and Sockets
goldyvb
13
Hi All,
We are currently completing some feasibility designs for some mobile mining units for a Client of ours. We have done similar units before where the transformer was located on the mining unit and powered via a 6.6kV trailing cable. In this case, they want to have an offboard 22kV/433V transformer and connect it up using low voltage plugs. We have done this before with Cavotec type single core plugs but these max out at about 600A, so to power this 2100A unit we would need 4 of these per phase plus neutral plus earth. Does anyone know of any other higher current plugs designed for use in a mining environment?
Many thanks
Michael
I had thought that 'Powerlock' connectors had an 800A option, but maybe I'm wrong: We'd used the 400A units for some plant we're assembling for a project.
That said, what restrictions do you have on number of LV cables feeding the unit? Unless you can get suitable cable sizes to both support the current and reduce the number of connections, its probably a futile exercise.
We ended up with 4 per phase for different reasons (and nowhere near your predicted current levels), but its potentially still a factor for you.
Victor Products might have something, although I can't see much above 500A listed on the website. Quality is pretty much up there with Cavotec.
image.php
