Dear fredE & others
Traditionally, neutralisation of fluoride-containing wastewater with lime is used. But frequently, the amount of lime required for neutralisation is insufficient for adequate fluoride removal. Furthermore, the separation of calcium fluoride from the wastewater is difficult and huge quantities of sludge are produced that might also contain other compounds in high concentrations. This bulky sludge often has to be disposed of as chemical waste.
Fluoride removal by crystallisation in a fluidised bed achieves effluent concentrations down to 5 (or even 2 mg/l with an additional filtration unit) in one reactor. The high upflow velocity of 40 to 75 m/h through the reactor results in a small footprint. The product is calcium fluoride pellets that are compact and virtually water free. They do not have to be landfilled but can be sold as a fluoride resource.
This technology is used for wastewater treatment or for removal of fluoride from water loops (reuse of water). When you search under the name " Crystalactor " you will probably find a supplier for this technology.
So FredE: The fluoride effluent concentration fits with your demand, the "waste" becomes a resource, the footprint is small and the technology is proven. I trust this has helped you
Jacco
