Hiding annotations 1
markwindsurf
Automotive
Nov 2, 2009
24
Does anyone have a Macro that hides annotation sets in top level assemblies, we are spending a lot of time open sub assemblies in large products to hide the text blocks and general notes, and am hoping someone has created a script that would allow us to do this at the top level product?
Thanks hopefully in advance.
Mark
work around on that
just record a macro to see how it hides annotations
Code:
Sub CATMain()
Set  ProductDocument1 = CATIA.ActiveDocument
Set Product1 = ProductDocument1. Product
Dim ProductDoc1_As_Document
Set ProductDoc1 = Catia.ActiveDocument
Dim Selection1_As_Selection
Set Selection1 = ProductDoc1.Selection
Product1.ApplyWorkMode DESIGN_MODE
selection1.Search "CATAsmSearch.MfConstraint,scr" 'hide Constrains
Set visPropertySet1 = Selection1.visProperties
VisPropertySet1.SetShow 1
Selection1.Clear
'~ Selection1.Search "CatPrtSearch.Surface,All"       'hide Surfaces
'~ Set visPropertySet1 = Selection1.visProperties
'~ VisPropertySet1.SetShow 1
'~ Selection1.Clear
Selection1.Search "CatPrtSearch.AxisSystem,All"
Selection1.Clear
Selection1.Search "CatPrtSearch.AxisSystem.Name=Axis' 'System*,All"
Selection1.Clear
Selection1.Search "CatPrtSearch.Line,All"            'hide lines
Selection1.Clear
Selection1.Search "CatPrtSearch.Curve,All"             'hide curves
Selection1.Clear
Selection1.Search "CatPrtSearch.Sketch,All"             'hide sketches
Selection1.Clear
Selection1.Search "CatPrtSearch.Point,All"                'hide points
Selection1.Clear
Selection1.Search "CatPrtSearch.Plane,All"                'hide planes
Selection1.Clear
'~ selection1.Search "CATGmoSearch.OpenBodyFeature,all"        'hide geometrical set
'~ Selection1.Clear
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
viewer3D1.Reframe
Set MyWindow = CATIA.ActiveWindow
Set MyViewer = MyWindow.ActiveViewer
End Sub
I remember this macro :) ...but I believe is not what is need it...
Try this
Code:
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set selection3 = productDocument1.Selection
selection3.Search "Name=*Annotation*,all"
Set selection4 = productDocument1.Selection
Set visPropertySet1 = selection4.VisProperties
Set visPropertySet1 = visPropertySet1.Parent
visPropertySet1.SetShow 1
selection4.Clear
End Sub
Fernando
- Romania
- EU
Ferdo,
Thanks for that have tried both Macros but am getting a message "stating the script entry point entry point could not be found Define a CATMAIN procedure which will be the entry point of the script.
What does this mean? should I put something in the brackets at the top of the script?
Mark
Ferdo, Correct all sorted now and functioning great.
