robsalv
- Aug 8, 2002
- 311
Hi Folks.
There seems to be fewer bolt queries in this forum than in the materials forum, but I figure I should ask a bolting question in the right forum first up, so hopefully you can help me out.
In looking through a company engineering spec regarding bolting and flanges, it conspicuously specifies A193 B8M class 1 bolting for service temperatures up to 815degC (1500degF) and flange classes 300# or less. Above this flange class it says you can't use class 1's without detailed calcs, but makes no suggestion about what you'd use in lieu of class 1, presumably class 2? (Interestingly, the specification defaults to class 2's for any SS bolting in cold service - which I would have thought you could have gotten away with the lower yield Class 1 studbolts...)
Despite looking over A193, I can't see what it is about class 1 B8M's studbolts that would make it more suitable for high temperature service than class 2 B8M's... I would have thought that at the higher temperatures you'd want the higher yield strength of class 2's especially if bolt relaxation at temperature is at all a concern - but this class 1 requirement sticks out like the proverbial so I'm thinking it could be some esoteric material thing that's beyond my Mech Eng brain.
I'm hoping one of you learned folks will be able to provide clarity on this issue.
Thanks in advance.
Rob
"Life! No one get's out of it alive."
"The trick is to grow up without growing old..."
Thanks in advance.
Rob
