I'm working on an assembly that joins an anodized/primed aluminum part to carbon fiber composite as well as joining two carbon fiber composite parts and manufacturing prefers using hi-loks. The application does not require a tension fastener.
For the aluminum - carbon part, I need to install the collar on the aluminum side. I'd like to avoid using a stainless collar given their issues with galling and the torque required to break the collar. I'm taking the appropriate steps to prevent galvanic corrosion between the aluminum and carbon composite (e.g., fiberglass ply, fay surface seal) but would like to use an aluminum collar on a titanium hi lok pin. Is the aluminum pigmented hi-kote plus an anodized/dyed aluminum collar acceptable from a galvanic perspective?
The same question applies for carbon - carbon joints. Not looking to crush the composite parts so an aluminum shear collar is preferred here as well.
