Hi Hi my calculations are finesh
chourouk
41
Hi
Hi
my calculations are finesh so I split the screen in two part on of for model compressed and the other part for the curve that I have drawn . now i want create a connection between the two half cad when the model is compress I see the point on the curve
thank you in advance
I am not sure what you are trying to do so it is not possible to help you. Could you explain a bit more what you are trying to do, also if you can include some images of your model and a description of your problem referring to the images provided, would really help us to understand.
Just to be clear: You are in postprocessing with your results and have two viewports side by side. One with a contour plot and one with a xy-plot. Now you want to synchronize them. So when you switch to the next frame in one viewport, that you see the new state also in the other viewport. Is that correct?
First you have to make sure, that the xy-plot has the time or frequency on the x-axis. When starting an animation in that viewport, you should see a yellow vertical line moving through the plot. Now you can click on the other viewport to make him active and start a time history animation here too. Usually both are automatically synchronized. If not, then you can do that in the animation options. Now you can also pause the animation and switch manually from frame to frame.
