Buildtech2
Hi Guys,
Presently, I am designing a chilled water system for residential blocks which can accomodate 400 workers, the chilled water system will also serve to re-creation center and a factory.
I have proposed two air cooled chillers of 300 tons each with a constant primary pump for each chiller and a 3 nos. duty / standby variable distributed pumps on the roof of three buildings. The design delta T for this system is 16 F.
There are 400 fan coil units, one for each worker room.
Now main worries are as follows.
1. Due to 16 F delta T, the chilled water flow in each fan coil unit is very low (1-1.5 gpm) and the pipe size is limited to 3/4" and chilled water velocities in the pipe is less than ASHRAE recommended. Do you think it will work..?
2. The variable distributed pumps are located on the roof of buildings (8m high) away from chilled water plant. Do we have to consider static head..?
3. Will there be any specific operating porblem in the system..Please advise.
