rob768
- Aug 3, 2005
- 441
Hi guys, I need some help (yet again).
i have an output set which contains the results of a forced frequency response calculation, spanning from 5 to 60 Hz, in 0,5 Hz steps. The calculation is performed in SI units, which results in vibration velocities in m/s. As the calculated values are low (max. 2 mm/s) I want to convert the results from m/s to mm/s (x1000) before I draw a graph with the charting option.
I tried model/output/process, but this doesn't give a good results (it creates a single output vector??)
Anyone any idea how to go about this?
Thanks in advance.
Thanks in advance.
