Hex entry into spreadsheets
  • Thread starter Thread starter -
  • Start date Start date
Guest
Is there a formula to convert a hexadecimal string into an integer?
First you have to initialize the toolpak.
Under TOOLS-ADDINS make sure the 'ANALYSIS TOOLPAK' is checked.
Then you can access the HEXTODEC converter.
Hope this helps...[reading]
Found in the PASTE FUNCTION - ENGINEERING category. [wink]
CrazyCarl:
It is actually called the "HEX2DEC" function and like meintsi said, it is in the "Analysis ToolPak". If you press F1 while in excel and type "HEX2DEC", excel help will tell you the steps to take.
Good Luck
jproj
My error...typnig TOO literally....
Thanks jproj
