HETVAL Subroutine compilation error
Alexander Koss
Automotive
DE
Dear Abaqus-Forum,
I am using a HETVAL Subroutine for my model with a material, that is supposed to heat up on its own. for some reason the Simulation aborts, and the following error appears:
Error in job Job: Problem during compilation - D:\Sim\uhetvalx.f
This is my file:
Check the log file for errors. That’s the code from documentation example, right ? There might be a problem with Abaqus and compiler linking if it doesn’t work.
Yeah, it turned out to be an issue with the install folder in Abaqus, the simulation runs if started on a different machine. Thank you!
