Help with slot connections in assemblies
NJH1982
5
I designed a lifting device/clamping fixture a while back. I decided to model it with Wildfire 2.0 and simulate it as a mechanism. I am new to the mechanism features of Wildfire 2.0 and ended up running into a problem.
The deign has an inline pair of 15mm pins spaced 25mm apart that travel through a straight slot milled into the designs main body, each pin restrains forward and aft motion along the milled slot. For some reason I can't set up the connections in assembly for this part.
NJH
You might need to go into the original parts and create datum points in the pin parts and a curve in your base along the centre of the slot. You may often need to add extra geometry like this to simplify the mechanism definition.
might want to bone up on skeletons :) real handy with mechanism
