fivechop
Mining
- Jan 12, 2013
- 11
Hi everyone, I have a problem to solve, imagine your standing on a platform 7 ft in the air and the only way to get to the ground is a stair stringer that raises and lowers in front of you rotating on an axis on the end of the platform on which you are standing. In the raised position the stair stringer is perpindicular to the platform and lowered it extends to the ground. Now here is the problem; the stairs used to be raised and lowered with a hydraulic pump system, now I am faced with the task of moving it with a non powered system ie. Torsion springs or some other means of stored energy. What I need to know is if there Is a method that I could use to lower the ladder and store enough energy to facilitate its return with little or effort. Any help or guidence would be greatly appreciated. Thanks
