Help with fanuc 18i series parameters
bob1371
Industrial
Hello
I am trying to find out what parameter I need to enable use of the real time clock for macro programming. The machine is a Muratec MS6 Lathe with fanuc 18i control.
Thanks,
Bob
Bob-
Are using system variable #3012 ?
it should give you the time in 24 hour format HHMMSS
4:12:32 PM would return 161232
Variable #3011 should give you the current date YYYYMMDD
Hope this helps
JBurgess
Thanks for the reply. I have been able to use the macro program options and #3012 on several of the machines with great results, however I still have 3 lathes that I cannot get to the macro's. I was told a parameter had to be enable to allow use of the macro variables. If anyone has this information It would be greatly appreciated.
Thanks,
Bob
not sure i can look in my books on monday and post back late monday night. But there is a quicker way you can call Fanuc at 1-888-fanucusa and ask them and they will tell you..
