Help with Dynamic Analysis
  • Thread starter Thread starter Ramone
  • Start date Start date
R
Ramone
Guest
I have created a model in which the force on a point increses over the time of my analysis. I have modelled this by creating a number of forces which I applyat certain times. These forces move parts of the mechanism upwards against gravity.
When I run the dynamic analysis the results show the mechanism moving to a point roughly where it should settle and then return to its origional position over a period of around 2 seconds. For a 10 second analysis, the mechanism resonates back an forth in a smooth motion.
I would expect the model to remain in a position or increse in height against gravity as the force being applied is increasing with time.
Is this how Pro-E shows this effect or am I applying the forces incorrectly. Can anyone tell me how I can change this to give a more realistic result.
Thanks in anticipation
you are applying the force incorrectly.
what you should do is apply force as custom load.
Thanks Israr,
I need to apply forces at different points from different points in time, i.e applying weights to different points of a cantilever see-saw after certain times.
Can you give me some more info on how I would do this
