dejan95
- Aug 24, 2020
- 60
I have just started my first job (mechanical engineering design) after graduation. As my first "big" project I need to design a work station. On this station i need to create a tool which will hold my work piece (a motor) in place. I would love to hear your insight.
Because the bottom part of the motor is made of plastic, I don't want to put stress on it. That is why I thought I would hold it in place with four pins (I might replace one pin with a sensor, so the station knows when the object is in place). The problem i see with this idea (you can see it in the pictures) is that it is hard to position the part, which doesn't make it perfect for fast production.
Do you maybe have any different ideas?
Thank you very much!
