Hi, I'm currently in a design phase of a variable speed 48vdc control for a fan. I want to connect the fan on the ac line so i need a ac to dc converter. I found out that the best solution is probably to use a switch mode power supply for the firts stage and a pwm buck converter to control the speed of the motor on the second stage. I need about 200 watts from the power supply at 48vdc to drive 3 seperate fans. My question is for the firts stage the power supply. Is there some integrated ic that I could use to simplified the design process? Or is there a simple way of doing what I want? I'm new to SMPS and dont know much about designing a high frequency transformer for it. Is there such a think as a commercial high frequency 48vdc secondary transformer at 200watt? thanks
Michael
Michael
