After posting on the "Antenna & Propagation engineering" forum, I have decided that this forum may offer the answers I need. I am involved in a post grad research project for material testing (welds in particular), and need assess the viability of several RF techniques.
My first question: I understand that Ansoft and HP HFSS are the industry standard for EM simulation, but have rather steep licensing costs. Are there any cheaper packages, or even assessment freeware, that will at least begin to allow me try out some initial design ideas?
My next question: I have looked through the RSGB and ARRL for suitable books to learn about microwave design techniques, there seem to be quite a few titles. Are there any in particular that are recommended? I'm OK with vect calc (from fluids), but am still getting up to speed with the Maxwell equations.
Finally: Since my research is going to need a lot of power (>1kW) into very low impedances, I have decided that the most sensible frequency to use is 2.45GHz. A lot of existing hardware seems to be available for this frequency, at the power levels I will require. Are there any techniques I should be familiar with (including the obvious safety requirements!)? I am interested in designing the apparatus to be as efficient as possible, since it is likely to become portable.
Graham
Graham
