I'm trying to size a pump for use in an aquarium system. The pump flow will be 2100 gph (35 gpm). The pump suction 7897:
According to your original post, you have three branches, one at 15 gpm and the other two at 10 gpm each, but your post of 23 Mar 07 13:32 states that only two operate simultaneously but you give different flows.
Anyways, here is the way you do it. The two largest simultaneous flows are one to a filter, say 15 gpm and one return to the tank, say 10 gpm. Therefore the total flow the pump needs to put out at any given time is 25 gpm.
What you want to do for the head loss calculation is to take the maximum total simultaneous flow of 25 gpmand perform the friction loss calculation from the pump discharge right up to where the first branch occurs. Let's assume the first branch is to the filter. To get the frictional loss from this junction to the filter, you use the 15 gpm flow rate. Then I assume this flow returns to the tank after being filtered. If that is all it does, then continue with the frictional loss calculation from the filter back to the tank. You need to account for final elevation differences between the pump discharge and the tank as brought up by Artisi. BUT, you also need to take into account a pressure drop through the filter. This may not be easy to come by.
If the flow from the filter joins back up with the other branch before returning to the tank, then the frictional loss of that part of the pipe is again performed using the maximum simultaneous flow of 25 gpm.
You then do the same thing with the recycle branch, using 10 gpm. This will give you another discharge head loss.
The discharge head loss for the pump will be the greater of the two branches. Now, you need to do a similar calculation on the suction side to get the TDH. The suction side is of course using the maximum simultaneous flow, 25 gpm.
Don't forget to also take into account any valves you may have in your system and of course the tee fittings that make up the branch take-offs.
Is this clear to you now?
