NghiaPP
Chemical
- Mar 7, 2005
- 25
I need some guidelines to make specification for a distillation column.
The vessel shall be designed according to ASME VIII div. 2.
Design pressure is 8 bar and design temperature is 250 deg.C, , material is CS.
As a consequence of a up set condition, the vessel could be filled up with liquid from normal level of 4 m to a level of 30 m, which will add around 2 bar extra to the bottom.
Do I need to given this information and the additional load to the foundation in the vessel specification ?
