Help on using Renew feature command 1
ranjithbelur
Automotive
IN
Is there a way(or any journals available) to apply renew feature command to all the features at once. Right now we can select only one feature at a time and it takes too much time to get done as we have the bigger model tree. Thanks in advance.
Ranjith P R
Automotive Seatings
Why do you need to do this for every feature? I would say only do this for features which require this.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Do you tried to select all items
and then right click and choose
edit.
Thanks for the reply.
@Nutace: I am facing problems while updating the features in NX11(original part was done in NX9). when I try to modify a feature, Some of the features under the original feature are failing. for this I got the renew feature as the solution.
So, without renewing features I can't work on the part.
@Ehaviv: We cannot select multiple features in Renew Feature command.
@Cowski: The reason is, I cannot work on the part unless I do this operation. Is there is any other solution for this problem(succesive features fail without reason when I modify a feature)?
Ranjith P R
Automotive Seatings
One possible solution would be to ask your IT department (the team that did the upgrade to NX11) to perform a Refile on your data.
The refile tool should take care of the "Feature Update" to NX11
I recommend to Refile to NX11.0.2. If you take an earlier release then you still have some features which need to be updated when using NX11.0.2
Keep in mind that which such a refile the data cannot be opened anymore in earlier versions of NX.
NX9 / TC10.1.2
Thanks for the reply NutAce and Cowski, that journal helped[thumbsup2]
Ranjith P R
Automotive Seatings
