lordrailie
Marine/Ocean
Hi all
we are getting now into a point where we don't know what to do with the design of our products.
Is it a good practice to disign in "context", i mean to to parts inside the assembly directly?. Up to now what I've seen is that if I do that, everythink works fine up to:
-the moment you take that part out of its context and try to midify it, or link it to other parts
-the moment you want to do a drafting, as wen you explote the assembly, the parts becomes red, and I cannot make an exploded scene out of it as it "not constrained totally" which means that if I explode it in the scene it wont come back
Or what to do....
I tried to instead of working in the context to open the part in a separate window, then copy and paste with link all the references i need for the creation of my new part and then start working. but...
-then when I modify anything, to update the part I have to load al the parts where i took references from, which i might not know, and catia does not tell me, all the references surfaces and solids come with an ?, and in the porperties or link does not say anything about where is pointing.
-Its tedious to have to copy all the references from one part to the other etcetc..
-and when i put it in the product, is placed in the space in its correct place but is not constrained.. so should constrain it...
I actually don't know which way to go.... When the think goes to big assemblies with linked parts it gets complicated...
Or what to do....
