bluespark1978
Good morning ladies and gentlemen,
I have been having an issue with one of the machines in our manufacturing plant. The piece of machinery in question is a grab unit. The issues we are having are that it is suddenly dropping during running, sometimes it only drops an inch but it has been seen to have dropped up to 36 inches. It doesn't happen all of the time and is very intermittent.
The grab weighs approximately 1000Kg maybe slightly more and it is lifted with a chain drive arrangement which is run by a Bosch-Rexroth synchronous motor and gearbox with the motor brake rated at 32NM.
I was doubtful about the motor being faulty as it is only 4 months old but the grab has been reworked and made slightly heavier than before. I am curious whether the added weight means the brake may not be rated high enough anymore of whether it is simply a motor fault. Any ideas or suggestions on either option would be appreciated please, I have not really done any motor torque work since college which was more years ago than I would like to remember.
Thanks all.
Thanks all.
