help needed in finding manufacturer
poolclamps
1
I need help in finding a manufacturer to fabricate 316 marine grade stainless steel clamps for my business.I have no problem in Spain with the component but would rarther give the work to a uk company. The component is basically a 50mm wide 316 steel rod, 220mm long with a 16mm wide slot in one end to clamp onto 12mm glass.Can anyone help???
This site may not be the best place for general machine show recomendations, it might even contravene the rules of use.
However, I'll throw one UK shop out for you, Portsmouth Aviation
