Shaft is made from 4150 non-resulphurized steel, machined from a 11.5" (292mm) bar. The subject diameter is 7" (178mm) where we need to know the estimated Brinell hardness.
At the OD of this material the Brinell is typically 269/321. However, the information we have from the vendor stops at 8" (203mm) diameter with that Ultimate Tensile listed at 115ksi.
Since this part was machined instead of forged, the properties diminish closer to the center. What I need to know is approximate Brinell reduction at different diameters from the outside working inward.
THANKS!!!
I'll also post in Metal & Met Eng. forum
Timing has an awful lot to do with the outcome of a rain dance.
THANKS!!!
