racookpe1978
Nuclear
- Feb 1, 2007
- 5,984
Need your help (and critism!)
I am deployed overseas (in Europe) in a power plant through the New Year. Our temporary pump and motor unit is on a mounting bed 1.0 mtr x 2.4 mtr (40 inch x 96 inch) weighing 5800 lbs. (A second filter and valve skid is heavier at 9600 lbs, but I can take those pieces apart to lower the net "moving weight" to less than 5000 lbs.)
So the 5800 lb pump is the heaviest load going across the grating. At 4 rollers under each corner of the pump skid, I have a 1450 lb "point" load on a roller of around 4 inch long = way over the grating limit. (The plant (our customer) wants to put 1/8 plate over the grating as a rolling surface, but the point loads seem way too high under each wheel.)
The grating is rated at 1000 lb/sq meter. Fine. But this rgating is mounted on a strutural network of W14 beams 1.5 meter (60 inch) on center. (W30 girders support the W14's below the grating.)
If I put a heavier plate [1/2 inch (12 mm) or 3/4 inch (19 mm)] over the grating so each end of the 1/2 plate is over a W14 beam , then the point load would appear to transfer from the roller through the 1/2 plate through the grating down to the W14.
Will that plate be enough of a cantilever (in the spaces between the the W14's) to avoid collapsing the grating?
