Help modifying a VBA Code 1
YEngineer
Petroleum
CA
The code below calculates the minimal distance in space of between two lines.
Points of line 1 have their coordinates x,y,z in columns c,d,b and those of line 2 in columns r,s,q. The minimal value is displayed in a message.
I want to change the macro so that each minimal distance for each point on line 1 is calculated and displayed in adjacent cells in column e. I tried to modify the macro by adding a loop calculation but failed miserably. Can somebody help?
Sub find_closest_distance()
With Worksheets("sheet1")
x1 = "c": y1 = "d": z1 = "b"
firstrow1 = 5
lastrow1 = .Cells(.Rows.Count, x1).End(xlUp).Row
x2 = "r": y2 = "s": z2 = "q"
firstrow2 = 5
lastrow2 = .Cells(.Rows.Count, x2).End(xlUp).Row
ning = .Cells(8, "x")
eing = .Cells(9, "x")
Eion = .Cells(7, "x")
min_distance = 1E+300
For i = firstrow1 To lastrow1
x1_acc = .Cells(i, x1): y1_acc = .Cells(i, y1): z1_acc = .Cells(i, z1):
For j = firstrow2 To lastrow2
x2_acc = ning + .Cells(j, x2): y2_acc = eing + .Cells(j, y2): z2_acc = Eion + .Cells(j, z2)
dist1 = (x1_acc - x2_acc) ^ 2 + (y1_acc - y2_acc) ^ 2 + (z1_acc - z2_acc) ^ 2
If dist1 < min_distance Then
min_distance = dist1
min_i = i: min_j = j
min_x1_acc = x1_acc: min_y1_acc = y1_acc: min_z1 = z1_acc
min_x2_acc = x2_acc: min_y2_acc = y2_acc: min_z2 = z2_acc
End If
Next j
Next i
MsgBox "Then miniumum distance is " & Sqr(min_distance) & " from point (Z = " & min_z1 & ", X = " & min_x1_acc & ", Y = " & min_y1_acc & ") to point (Z = " & min_z2 - Eion & ", X = " & min_x2_acc - ning & ", Y = " & min_y2_acc - eing & ")"
End With
End Sub
Ammended code to write minimum distance for each row to column E, point on Line 2 to Column F and overall minimum and points to cells E#, G3, and I3:
Code:
 min_distance_i = 1E+300
 If dist1 < min_distance_i Then
 min_distance_i = dist1
 min_j_i = j
 End If
 Next j
 .Cells(i, "e") = Sqr(min_distance_i)
 .Cells(i, "f") = min_j_i
 If min_distance_i < min_distance Then
 min_distance = min_distance_i
 min_i = i: min_j = min_j_i
 End If
 Next i
 .Cells(3, "e") = Sqr(min_distance)
 .Cells(3, "g") = min_i
 .Cells(3, "i") = min_j
 End With
 End Sub
Doug Jenkins
Interactive Design Services
Thank you very much IDS, it worked. For future references for the guys who do not know VBA the array formula is:
MIN((($B$5:$B$500-Q5-$X$7)^2+($C$5:$C$500-R5-$X$8)^2+($D$5:$D$500-S5-$X$9)^2)^0.5)
thanks again IDS
