Hello and thank you in advance!
I'm looking for information regarding the grounding of pool fence. I have a situation where there is about 1500 L.F. of ornamental aluminum pool fence enclosing a large area with three pools and two spas that I need to ground. I've found some information regarding the grounding of fence at the NESCC, but those details I've seen are for Electric Supply and Comm. Facilities. Other information I've found suggest a ground rod every 100 L.F. and even every 500 L.F.
I should note that this is NOT electrically charged fence, just ornamental aluminum fence. Fence posts are dirt set in concrete.
Are there any specifications available for this type of situation? What would be the best recommendation here? Any help would be greatly appreciated, we want to be safe.
Thanks,
Taylor
