Help determining the equivalent mechanical system for a filter?
achilles03
Aerospace
I'm a little rusty on my circuit analysis, so I was hoping someone more well-versed in circuit analysis could give me a little help in figuring out a filter I'm interested in. I believe it is a Butterworth filter.
I'm a mechanical engineer, and it'd be easier to set up the differential equation if I could visualize it mechanically. So, if anyone could help, what would the equivalent mechanical system be for the following filter?
I think that it's a dashpot and spring in parallel with a mass (I hope this pastes ok):
---DASHPOT----| |
| mass |
----SPRING------| |
...but I can't figure out where to place the left-most capacitor. Is in in series with the dashpot?
The end result is that I want to model the transient response (using a step-time type integration) for non-linear voltage inputs (square, saw, etc).
Thanks in advance for any help!
Dave
It looks like I was incorrect in calling it a Butterworth filter. It looks like this is a pi filter.
Code:
                       Fv1 |     |  Fv2
     (fixed) o--@@@@@---+--|  M  |--+---@@@@@@---o (fixed)
                 Kc1       |     |  |    Kc2
                 spring    +-----+  |  spring   -+
                                    +-----------||----o (fixed)
                                              dashpot
         Where: electrical param                mechanical param
         V1 (voltage)                           Fv1 (force)
         V2 (voltage)                           Fv2 (force)
         Il (inductor current)                  Vm  (mass velocity)
         Qc1 (charge on C1)                     Xc1 (spring displacement)
         Qc2 (charge on C2)                     Xc2 (spring displacement)
To apply V1, apply a force to point Fv1. To measure V2, measure the force
between the mass and Fv2.
Unless you do a Bode plot, there's no way to tell, other than that it's a low pass filter, given the series L and R.
However, the pi filter cited has 4 passive components, while the mechanical "equivalent" only has 3.
TTFN
FAQ731-376
1 mass, 2 springs, 1 dashpot... that's 4 passive components.
