Hello all,
we are replacing an existing turboexpander-compressor with new smaller size one due to lower plant inlet flow.
the capacity of the compressor has changed from 345 mmscfd at normal operations to 115 mmscfd. with this new expander-compressor, the need for recycle flow on the compressor has changed. My question is what is the effect of the smaller compressor capacity on the current size of the anti-surge valve? We are planning to change only the expander-compressor with no other chagnes. Do we need to reduce the Cv of the anti-surge valve? I found that the current Cv valve requires 1% opening for 5 mmscfd recycle flow. What are the risks of using this big size anti-surge valve in controlling such small flow? at 115 mmscfd the opening will be 22%.
Please advise how I can analyze the situation of surge control with the smaller compressor capacity?
I appreciate your inputs.
Iradah
Iradah
