Hello all,
I am looking for a gizmo to remove pumps on chains from wet wells.
To use the gizmo, you put the gizmo on the end of the cable to your hoist or winch. Then put the chain through the gizmo and let it slide down the chain to anywhere you like on the chain and reel up your cable and the gizmo grabs the chain and up it comes.
When you are done servicing the pump, you reel the cable down with the gizmo attached to the chain to the desired level and give the gizmo a shake. The gizmo disengages from the chain and you reel it up.
I have seen one once and the only ID on it was "made in China". Some folks have seen them but do not know where to purchase one. I have looked in many catalogs with no luck.
I am hoping someone out there can give me some info.
Thanks in advance.
Thanks in advance.
