Helix with a Bend 1
quest4k
Industrial
Aug 31, 2005
382
Good afternoon, I have a helix, to make a spring. On each end of the helix I have a fully defined radius, to make it look like I bent the spring. I attached a circle to the first radius, again fully defined, and tried to sweep the entire thing, but it only went as far as the first radius. Now if this matters, the two radiuses on the ends of the helix were grey in color. What is wrong with what I am tring to do? I did use pierce when ever possible. Any suggestions on how to sweep the entire thing? Thank you in advance for any assistance.
Can you show a pic? Seems like the "radii" are not touching the helix.
Chris
Systems Analyst, I.S.
SolidWorks Pro 06/PDMWorks 06
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
yes you you tell me how. I used pierce to join themso I think that should take care to that situation.
Did you try to create a composite curve from the end radius curves and the helix? Then use the composite curve as your sweep path.
faq559-1100
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
That did the trick. Thanks alot.
