I think for the most part that one confuses rotorcraft mechanics from rotorcraft engineers. Now if you go look that topic up you probably wont find it. But there is an entire branch of Aero and Mech Engineers that are devoted to Helicopter Engineering and I have had the opportunity to meet most of them.
There is an inherent difference from "Constructing" an Airfoil from parts and components, to "Designing" one from scratch.
Just because you have some NACA data, does not mean that your airfoil or rotorblade will withstand the stresses setup in the rotor. Composites can pose another serious problem if not taken into account. one of which if not done correclty is delamination. Bell Textron found this to be a problem with their early 680 composite yoke assemblies and their other rotor blades of like natures.
I would also ask you to take into consideration for the needs of "inertia". if a rotor blade is made of composites, a couple of things off the top come into mind.
1.) Rotor Dynamic and static ballancing becomes more critical.
2.) Blade Mass, which if not high enough or with enough weight(s), can lose inertia rapidly during any power failures, I personally would not want a composite blade for such reasons.
3.) in composite designs of rotor blades, blade flapping and blade center of mass can become compounded problems during both normal and not so normal flights. If your rotor does not have the proper ballancing, then your coning angles are most likely to be quite high, which will force teh blade cm inward. when this happens lift is lost due to ever increasing blade cone angle. In other words, as the blades flap up, their lift gets destroyed. So the lighter the blade, the greater your tip weights should be to offset this, plus tip speeds. which brings us to another point.
4.) Your composite blade will now have to be calculated for the centrifugal forces and centripetal accelerations set up whithin the rotors. This means that unless you pay attention to the coefficients of expansion, along with a myriad of other problems, your rotors are going to "de-elaminate".
I would strongly urge you to find one of two things:
A.) Already constructed 0012, 23012, SC1095R etc, or the like airfoils and use them, or.
B.) find someone that knows the "Design" aspects for helicotper rotors, spindles and cuffs, lead lag motion and damping, and feather hinges. There's too much to go wrong, will you sacrifice your life for the 6 seconds prior to delamination?
Hope this helps.
I Have designed a method for tilting the main rotor of a helicopter independant of the fuselage and transmission. I own a Company Called Moylan Grass LLC in Minden, NV. We are startup and are in the process of acquisition of funding to begin helicotper manufacturing. U.S. Pat. 5,740,987
Good Day all.
