helical sweep
mustangmike
21
Does anyone know if it is possible to make a helical sweep follow a trajectory curve instead of an axis? I want to show a coiled cable bending. I am using PROE Wildfire 2.0
Mike,
If you want to bend a coiled spring... make your spring
as you would normally..helical sweep
then apply a spinal bend to it
if you go help on it , it has a example...but if you need more let us know
you will get some deformation... it's good for representation.. it's not going to be the true way a spring bends. as one side will squish and the other expands
thanks for the help.
I have tried the bend but didn't know exactly what to do when I had to enter the equation for the curve.
Mike,
Check this thread554-67609 I like Ticks response use The Law of Curves....Variable Section Sweep with Trajpar
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Just to add to TheTick and mjcole's respones to the aforementioned post:
Create a circle at the trajectory origin, right click on it and convert it to a construction circle. This circle sets the diameter of the coil.
Create a single line from the origin to the perimeter of the circle, making sure it is not snapped to horizontal or vertical.
Then create the relation from the Variable Section Sweep's sketch as mjcole pointed out (sdXX = trajpar * 360 * N, where N is the number of coils).
The resulting surface gives you an the edge which is the basis for your second VSS, which represents your coil.
I finally got it. I was able to make a variable section sweep along curves. Then I did a projection sweep to get my coil along the curve. Does anyone know if it is possible to vary the distance between the coils on the same variable section sweep? I used trajpar*360*N where N is the distance between the coils. Is there anyway to vary "N" for certain lengths of the sweep?
