Helical sweep+datum point
  • Thread starter Thread starter rsahak
  • Start date Start date
R
rsahak
Guest
Please find out the answeer.
When I create a spring with circular section (Helical sweep>Thru Axis). Then creating a surface as copy from a one end of the spring.
This surface in Curve Analysis shows different Radii at Edge.
Finally, I need to find center of circular section on both ends of the spring to place datum points.
Regards.
rsahak
