T
theledman
Guest
I'm currently modeling a screw thread with a conical
style thread. When I machine this part, the tool cutting
the thread follows a conical path so that the core
diameter is increasing as it goes up the shaft of the
screw. Also, the width of the tool is wider than the
pitch itself so that at the start of the thread, the
outer diameter is also slightly conical (due to parts of
the cutting tool overlapping itself as it travels along
the tool path). I have attached a picture of the
prototype showing what was done.
<a href="http://postimage.org/image/m3k9c6rvl/" target="_blank">
[img=http://s8.postimage.org/m3k9c6rvl/IMG_20121213_162626.j pg"></a>
I'm trying to model this in ProE, but since the width of
the tool is wider than the pitch, the helical sweep cut
feature returns an error when trying to render it. I'm
not sure how to get around this. Any thoughts?
[b]Edited by: theledman [/b]
