Hello All,
I'm in the process of modelling several reaches in HEC-Ras. For each site(reach) we've obtained measured flow data (from a third party). We are to calibrate the HEC-Ras model to produce the same water surface elevation produced in the field.
I've attached a sample data set of the measured flow in excel format for reference;
The total calculated flow for this section is 739.74ft3/s, approximate profile grade where the section was measured is approximately 0.54%. The This reach gently meanders for several miles without obstructions. Accordingly, for tailwater conditions I've assumed that Normal Depth would be appropriate.
I've tried a couple of different methods in an attempt to calibrate the model (with a coulple of assumptions) but have been rather un-sucessful. I would assume that in a steady state model, the only variable to play with would be the mannings coefficient as we have a measured flow, channel geometry, normal depth and standard expansion and contraction (0.1 0.3). I've tried the following;
1) Attempted to calibrate the HEC-Ras model with the X-Section data above. I've completed iterations by adjusting the channel manning's coefficients to re-produce a depth at 327.67ft. I've also tried varying the channel n by station. In short, the manning's coefficient that I'm getting is in excess of 0.09. This reach and several others are in rockey type areas, however, based on past experience of calibrated models I would anticipate the manning value to max out at approx 0.05-0.06.
2) Attempted to reproduce results using flow master and the cross section tool in the FHA Hydraulic Tool Box. These methods have also produced a high mannings coefficient within the channel.
I was wondering if anyone has had experience with calibrating HEC-Ras models based on measured flow and could provide any feedback on the above? I'm wondering one of two things 1) Is there is another way to calibrate the data in which I have not considered? 2) There is an error with the data we've received?
Is there any reference material for calibration you could provide?
Thank you in advance for your feedback, it is greatly appreciated.
Ryb01
Ryb01
